- In praise of !ShareFS (News:10)
- Aemulor (Gen:9)
- RISC OS London Show 2017 (News:)
- Acorn-Gaming.org.uk (Games:9)
- Help getting RPCEmu working on a MacBook (Gen:10)
- Best BBC Micro game music (Games:42)
- !DualHead second release reviewed (News:)
- Equinox (Games:2)
- RiscStation 7500 Scorcher needs a home (Gen:4)
- September News round-up (News:)
- !Organizer reaches 2.26
- RISC OS on GitHub
- R-Comp release !DualHead
- Revisting the old Acorn magazines online
- RISC OS Interviews - Richard Brown (Orpheus Internet)
- Summer edition of Drag'N'Drop hits the shelves
- ROM release for your Titanium - What is new
The Icon Bar: News and features: !DualHead in use
!DualHead in use
Posted by Mark Stephens on 07:20, 8/9/2017 | ,
  !DualHead in use
  nytrex (02:15 11/9/2017)
  jimnagel (15:57 14/9/2017)
    arawnsley (21:31 14/9/2017)
      riscosbits (23:38 14/9/2017)
      Elesar (09:28 15/9/2017)
        riscosbits (10:43 15/9/2017)
Alan Robertson Message #124149, posted by nytrex at 02:15, 11/9/2017
Great to see developments like this.
Jim Nagel Message #124152, posted by jimnagel at 15:57, 14/9/2017, in reply to message #124149
What happens when an error box pops up? It would normally be in the middle of the screen, so does it fall at the borderline between the dual screens?
Andrew Rawnsley Message #124153, posted by arawnsley at 21:31, 14/9/2017, in reply to message #124152
There are pros and cons to both approaches - one big screen (eg. 3440x1440) on ARMX6 or dual monitor on TiMachine. For a start, two smaller monitors are cheaper than one 34" ultra-wide. As long as you use thin-bezel monitors, it shouldn't be a big issue. On the flip side, one big monitor is probably simpler for RISC OS .
RISCOS Bits Message #124154, posted by riscosbits at 23:38, 14/9/2017, in reply to message #124153
[Edited by riscosbits at 10:40, 15/9/2017]
Robert Sprowson Message #124155, posted by Elesar at 09:28, 15/9/2017, in reply to message #124153
In principle !DualHead could be extended to add a Wimp filter that spots windows trying to open centred, and move them to the left (or right).
Dell sell a quad picture by picture monster https://www.engadget.com/2016/05/23/dell-43-inch-quad-monitor/ though 43" may require buying a bigger house first!
RISCOS Bits Message #124157, posted by riscosbits at 10:43, 15/9/2017, in reply to message #124155
I really like the "where your eyeballs are" idea, but would prefer an option to not do that, in my "one screen" situation.
And a bit added on to the mortgage!
