- RISC OS interview with Tim H-Smith (News:1)
- 55 BBC Micro Books on CD (News:)
- RISC OS interview with Richard Keefe (News:3)
- The South-West Show Report 2018 (News:9)
- February News Round-up (News:)
- The South-West Show 2018 in pictures (News:)
- AMCS free versions are live! (Gen:12)
- New RISC OS !FamTree application reviewed (News:1)
- Returning to ImpressionX (News:)
- South West Show is fast approaching (News:4)
- NetFetch reaches Version 5
- BBC BASIC Reference Manual updated
- ArtWorks 2.X3 released
- Drag'N'Drop Autumn edition now available
- !DualHead puts 2 screens in one
- !DualHead second release reviewed
- !DualHead in use
- R-Comp release !DualHead
The Icon Bar: News and features: !Organizer 2.28 reviewed
Posted by Mark Stephens on 07:48, 24/11/2017 |
!Organizer 2.28 was released at the London Show.
The software comes as a single zip file and there are instructions on how to install or upgrade. When you first run the software, you will be asked about how you would like to update. The default is Y for each. I found I had to save the default choices back at the end.
The headline feature in this release is the rewrite on the planner mode. This is really slick and will display as many weeks forward as it can comfortably display. So on my 1920x1200 screen, I can see the next 14 weeks in a very readable vertical format. If you have a higher resolution you will get less weeks - the software adjusts to fit what makes sense for your display size. I have always been a 'two weeks display mode' user up until now but I am now experimenting with this display.
There are also some nice-to-have features in the software including a better print dialog box and the !Organizer window can be moved or resized by dragging any corner.
The release note says that there have been under the hood changes to improve the software and speed it up. It certainly feels very smooth in operation on my Titantium. Tab and backtab (tab with shift key pressed) allow you to cycle onto the next or last week. If you are in mutli-week modes it moves forward/backward just one week - it does not jump 14 weeks forward in my full display!
The website itself could do with a little TLC. The !Organizer Version History is very out of date and could probably just go.
!Organizer are also still asking for more suggestions on features for the next release.
Overall I am really pleased with the new features in 2.28 and I recommend it as an upgrade to all existing users (and well worth a look if are not using it).
!Organizer can be purchased from the website with the usual discounts for existing customers.
  mavison (11:13 24/11/2017)
  mac9 (19:14 26/11/2017)
Martin Avison Message #124223, posted by mavison at 11:13, 24/11/2017
Thank you for reviewing Organizer v2.28. In fact the Planner was only changed slightly - it was the other Diary display formats which were changed to match the Planner, and they now all will display multiple columns if the window is wide enough. Also with higher resolutions the wider the window can be made, and the more weeks will be seen.
Andrew McCarthy Message #124226, posted by mac9 at 19:14, 26/11/2017, in reply to message #124223
A feature that would provide me with the impetus to buy !Organiser would be the facility to synchronise with internet calendars; google, microsoft, etc...
